Anyone else having a problem opening Tor. When I open Tor it says I need to upgrade from 5.0.3 to 5.0.4 but then the Digital Signature errors out and it closes.
I have not experienced this problem. But, I am using Tor on UM 14.04 64 bit, if that makes any difference.
i would solve the problem by simply deleting the Tor folder and reinstalling the latest version.
Thanks Steve - I’ll give it a try
