Problem updating
I am getting:
E: Repository 'http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease' changed its 'Label' value from 'Oracle Java (JDK) 8 / 9 Installer PPA' to 'Oracle Java (JDK) 8 Installer PPA'
Any idea how to fix this?
Software & Updates
click on the Other Software Tab and find the old java ppa and delete it then click the Add button here is new to add
Type is Binary
URL is http://ppa.launchpad.net/webupd8team/java/ubuntu
Distribution is bionic
components is main
leave the comment blank
after that close it and reload the repositories
Hope this helps
That is actually the default setting that I have that is causing problems.
EDIT:
I don’t think it’s the PPA. It’s the Label of something inside the PPA. Check out the screenshot I added at the beginning of this thread.
I removed the PPA and added it again through Software & Updates, then updated but still had the same problem.
What did work for me ultimately, though is:
  1. Removed PPA through Software & Updates->Other Software->Remove. (Close/Reload)
  2. Rebooted.
  3. Opened a terminal and did:
sudo add-apt-repository ppa:webupd8team/java sudo apt-get update
