Problem with broken package wine i386
Hi Guys,
I hope you can help me with this problem.
I got the following notification in the package manager on Ubuntu 20.04
Broken dependencies Package -> wine:i386 Installed Version -> 1:16.5-0ubuntu14 Description -> Microsoft Windows Compatibiliity Layer (meta-package)
And then I tried to update and upgrade my system but there is an error
You might want to run 'apt --fix-broken install' to correct these
wine:i386 : Depends: wine1.6:i386
I tried the suggested command but there are some errors at the output
Do you want to continue? [Y/n]
(Reading database ... 304384 files and directories currently installed.)
Preparing to unpack .../wine1.6-i386_1%3a1.6.2-0ubuntu14_i386.deb ...
Unpacking wine1.6-i386:i386 (1:1.6.2-0ubuntu14) ...
dpkg: error processing archive /var/cache/apt/archives/wine1.6-i386_1%3a1.6.2-0ubuntu14_i386.deb (--unpack):
trying to overwrite '/usr/lib/i386-linux-gnu/wine/jscript.dll.so', which is also in package libwine:i386 5.0-3ubuntu1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
YPreparing to unpack .../wine1.6_1%3a1.6.2-0ubuntu14_i386.deb ...
Unpacking wine1.6:i386 (1:1.6.2-0ubuntu14) ...
dpkg: error processing archive /var/cache/apt/archives/wine1.6_1%3a1.6.2-0ubuntu
trying to overwrite '/usr/share/wine/fonts/wingding.ttf', which is also in package fonts-wine 5.0-3ubuntu1
Preparing to unpack .../libp11-kit-gnome-eyring_3.18.3-0ubuntu2_i386.deb ...
Unpacking libp11-kit-gnome-keyring:i386 (3.18.3-0ubuntu2) ...
dpkg: error processing archive /var/cache/apt/archives/libp11-kit-gnome-keyring_
3.18.3-0ubuntu2_i386.deb (--unpack):
trying to overwrite '/usr/share/p11-kit/modules/gnome-keyring.module', which is also in package gnome-keyring-pkcs11:amd64 3.36.0-1ubuntu1
Preparing to unpack .../libpng12-0_1.2.54-1ubuntu1_i386.deb ...
Unpacking libpng12-0:i386 (1.2.54-1ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/libpng12-0_1.2.54-1ubuntu
1_i386.deb (--unpack):
unable to install new version of '/usr/lib/i386-linux-gnu/libpng12.so.0': No such file or directory
No apport report written because MaxReports is reached already
Errors were encountered while processing:
/var/cache/apt/archives/wine1.6_1%3a1.6.2-0ubuntu14_i386.deb
/var/cache/apt/archives/libp11-kit-gnome-keyring_3.18.3-0ubuntu2_i386.deb
/var/cache/apt/archives/libpng12-0_1.2.54-1ubuntu1_i386.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hi Hector,
Easy to repair broken packages by mate software boutique - fixes - configure interrupted p & resolve broken p.
Lucky
Good night Tim,
Thanks for your support, now it is fixed
