I'm on UbuntuMate 21 - not yet gone to 22.
I have a Brother wireless printer (DCP-J315W) installed some years ago, printing with no problems, except I discovered recently that it would no longer be found as a scanner using the simple-scan 'feature'. I suspect it was something to do with networking in updates.
The driver software on the Brother website is the version I originally installed, and the print feature works from all the other machines on my local network.
I don't have the option of plugging the printer as it only offers wireless connection.
Does anyone have any idea how to get it working - is it a matter of ports used which are no longer open, possibly?
Hello dandnsmith
Use Synaptic to install the following package: "libusb-0.1-4"
Reboot, just to be on the safe side.
Did that help?
I tried that - it reported that that was the version already installed. Rebooted, tried simple scan - reported 'no scanners found'.
try installing Xsane. I had the same issue, so I installed Xsane, used it once then Simple Scan started finding the scanner.
I'll give it a go, and report back. Thanks
I installed xsane - but ran into a problem of how to use. Found too many pages, but mostly relating to wired connection rather than helping with wireless.
Hello again dandnsmith
Your printer model does have a USB-connection (it is not on the outside of the printer though) according to product reviews from 2011 found on the internet.
Have you tried using it connected via USB?
USB is (most probably) for memory devices holding pictures. I would need UTP for ethernet - which it definitely doesn't have
Hello dandnsmith
Please consult:
[1] user manual diagrams showing how to install the USB cable
[2] youtube showing where USB cable goes
You can connect your printer to a computer via a permanent USB cable connection.
Thanks for those links. Since my last post, but before reading yours, I found the bits in the users guide on connecting to computer via USB.
What I don't know is what I needed to install in Ubuntu to drive it - I'll have to look further for help on that. Possibly I just need to connect and see if I have it available as a printer - I'm a little chary of doing that as the printer is used via several machines over the local network, and everything here is somewhat in a mess as I prepare to move house.
I'll post again when I have more info.
