This is pretty weird. I’m running Ubuntu-MATE 15.04 on a Dell Studio 1745 laptop and last night there was an kernel upgrade from 3.19.0-30 to 3.19.0-31. After installing it I rebooted and at first everything was fine… for about 30 seconds, then the mouse pointer just stopped working completely. Couldn’t move the pointer & no left/right clicks either. It’s a Logitech M570 wireless trackball, by the way. Tried the built in touch-pad, same thing.
So I had to hold the power button for 4 seconds & tried again, thinking that it might have been a glitch. Boots up fine & this time I got as far as opening the menu & was going to click on a program & yep, same thing happened. Tried unplugging the wireless dongle & rebooted to see if maybe the latest kernel had problems with it. Still did it after loading desktop.
There’s no problem when I go back to 3.19.0-30 kernel, so I deleted the 3.19.0-31 kernel via synaptic & locked the 3.19.0-30 kernel files. My problem is, I can’t tell if this IS a Track-Ball/touch-pad issue, or perhaps just the system crashing. Checked /var/crash folder, no crash reports shown and none of the other log files in /var/log show anything unusual.
Is anyone else having problems with this new kernel? Will I still be able to get updates, just not new kernel ones? Will this affect the upcoming 15.10 upgrade? And final question, I promise, will I be able to see if there is a 3.19.0-32 kernel upgrade in Synaptic while the 3.19.0-30 is locked?
Tune in tomorrow for another episode of “When The Kernel Popped”!
Thanks for reading!
