Hi everyone,
I’ve installed caja image converter from the official .deb package.
The installation gone well but the image converter doesn’t work and I can’t see “resize image” on the context menu.
Does anyone know the reason?
thanks
Hi everyone,
thanks
did you logout/login? I installed that package and after logout/login, the context menu has resize images (under Revert to previous versions …)
You beat me pavlos Just did that too.
Yes I’ve logged out but still doesn’t work.
I’ve also tried to install the package from terminal but it doesn’t change.
Where did you find your package pavlos?
thanks
I’ve solved after a reinstall from the ubuntu software center.
thanks
