Good day all, quick question. What would be your recommendation for a programme to monitor the wireless environment from UM? I have used KISMET in the past, but is there another programme I could use as an alternative?
Thanks!
Hi @andyp6, I use wavemon, available in the repositories. It’s a simple terminal (ncurses) program that can be configured many ways. The biggest drawback is it needs to be run as root/sudo.
And I’ll join you watching to hear what others use.
