Progress report as we approach 18.04 Beta 2
That's exactly what happened. Depending on which beta version you started with there was a change in the mouse\touchpad driver which had a bug that was fixed in subsequent updates because it got reported here and the developers were able to request the sources be synced with the fix.
Just goes to show how important people getting involved with betas and testing really is!
I’m going to test the daily builds and will give a feedback in some Hours !
http://cdimage.ubuntu.com/ubuntu-mate/daily-live/
I will also install ALL apps from Software boutique and check if there is any issue
So here are all Bugs i found Installing everything on Software Boutique
→ Installed all Packages/Softwares
Found a new bug : Sometimes When installing an app , WHILE the brisk menu is open . Brisk Menu Crashes
Ubuntu Mate 18.04 Daily Build April 12
1 - Error - Package subsurface isn’t available
2 - Error - Spotify not found URL / isn’t available (This is weird because it works in Snap Store)
3 - Error Package gcompris-data isn’t available
4 - Error Package dia-gnome isn’t available
5 - Error Package wavebox isn’t available
6 - Error Package insync isn’t available
7 - Package wavebox isn’t available
8 – New bug : Sometime while Some Softwares are being installed . Firefox Hang in, and it’s impossible to use for like 6 to 10 seconds ( I don’t know if this bug is particular with firefox ?)
PS: This is a solid install , no VM !
My Hardware : Amd RX 480 2gb ddr5
320gb SATA
Intel Core i5 3.3
10 gb RAM ddr3
Intel MOBO
± 50 mb ISP<img src="/uploads/default/original/2X/8/8e48c9f1217110fd47e36c06fb9544a69d3acb87.png" width=“400 height=“300”><img src=”/uploads/default/original/2X/9/9ec7203340f55864b37fe26d18b7ce7ff0e44c14.png" width="500 height=“400”>
Bug or suggestion for improvement:
In the Software Boutique, if you press any of the “Details” button and then “Screenshot” and instaed of closing the screenshot window you click in the Boutique window (by accident or because you think this will close the preview) the preview window remains open and goes below the boutique window. In that condition, you can navegate the boutique but the buttons (Details and Install) don’t respond. This can be disconcerting until you realize the other window is open and close it or you close the boutique and retry.
I'm testing todays daily ISO (bionic-desktop-amd64.iso, md5 = 726364dbd7cc5370f5984e8bd94fc5de) on VirtualBox 5.1.34 (Xenial MATE is the host).
Sometimes I get screen corruption on first boot of ISO using default Try Ubuntu MATE without installing.
Pressing RightCtrl+F1 and then RightCtrl+F7 fixed issue.
ISO installed normally, then I installed VirtualBox Guest Additions 5.1.34 on guest.
Visual problems:
  1. problem with low contrast of selected text exists reported as bug 1763942;
  2. keyboard LED indicator has low contrast on light themes (see bug 1728715)
  3. mate-welcome has low contrast on Radiant-MATE theme (it is bug 1762024)
  4. human-theme problem exists (see bug 1721955);
Other problems:
  1. Pluma problem with TypeError: Couldn't find foreign struct converter for 'cairo.Context' after enabling all plugins remains - bug 1743134;
Positive moments:
  1. Bugs with Pluma plugins were fixed. Thanks to @Wimpy!
  2. caja-dropbox autostarts with system (bug 1604439 is fixed).
Running Bionic as host and found vBox 5.2.8 runs without the corruption issue that I also seen in earlier version .
Just curious, has there been any movement on whatever is causing the trouble with GDebi?
What is the problem with your GDebi? Mine works as expected.
@bornagainpenguin Gdebi is fixed for a couple of weeks now :slightly_smiling_face:
Well I’ve been installing everything in terminal, so I didn’t know. I’ll have to grab a DEB file and report back because the last one I tried to install (a day or two ago) still disappeared without offering me to input the password to authorize installation.
EDIT: Curiously I still seem to have part of an issue. If I download the DEB in my browser and double click the DEB, GDebi will open it and allow me to hit the install button but will not bring up the superuser password dialog. If I go to where the DEB file is and open it from Caja, everything goes as expected. At this point all I can do is speculate that this is something happening with Pale Moon. I will seek out another DEB and try to install from Firefox for comparison purposes.
UPDATE: No this is still happening for me with Firefox too. The application simply does not bring up the superuser box to allow authorization for an install.
I can report Gdebi seems fixed. I reinstalled yacreader and it’s libunarr dependency today, and they both went off swimmingly. My bare metal install is yesterday’s build (April 17th)
I experienced the same trouble installing Spotify from the Boutique as Gabdub, but it installed just fine from the Gnome Software repository (the one that looks like a white and blue shopping bag) I have had trouble with Opera in the past as well, but it installed just fine from the Boutique.
Great feedback, thanks. Should all be resolved in the new release of Welcome. subsurface is not available for Bionic yet and dia has been dropped.
The package names for dia have changed, it can still be installed on Bionic. That said there is some artifacts in UI so I removed it from the listing on Bionic on the ground it is no longer of sufficient quality to be featured.
edit : No issues with Applets now !!
great job !!
And is the “Select Layout” option removed in the “welcome snap” ?
anyways good job
i’ll give more feedback
Temporarily, yes. But it will return.
Is the software botique ever going to be a full software store or is it only going to always showcase certain apps
My understanding has always been that the goal is for the latter, a curated collection, not everything. So just like a clothing store may carry everything, a clothing boutique only has a limited selection of the best items. You can always install Ubuntu Software if you want a full software center.
I understand I just thought I had read something about it being different, but maybe that was speculation
@Bernie - the software boutique is actually manually curated for every release, so it would be impractical to have more than just a showcase of software that is known to work well.
I think there may be a plan to move the software list to an online service so that the list can be updated without requiring a new version of the boutique, but it would still be curated manually. I remember hearing this somewhere at some point, but not entirely sure, so take it with a grain of salt :slight_smile:
Ok I understand I did not realize that was how the Boutique worked that is
interesting
@vkareh’s right about Software Boutique, so take his words with a few bags of salt :smiley: :moneybag:
It is planned for the next generation of Software Boutique (2.0) to become a fully featured software centre, but it’s quite an objective and is taking a bit of time since it requires the application to be re-written from the ground up. Also factor that it’s developed in our free time which can be limited and occupied with other things. :slight_smile:
