This works but there is a potential problem. If I do a Ctrl C to stop it, the re-enabling of suspend is never reached.
# Stop computer from sleeping while timer is running
echo Computer will be suspended from sleeping while timer is running.
echo
echo fake | sudo -S systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
if [ $# -eq 1 ]
then
DURATION="$1"
else
read -r -p "Timer for how many minutes?( for fractional use decimal notation , 0.5==30s, 1.25==75s etc) : " DURATION
read -r -p "Enter text to display at the end of the timer : " n1
fi
# To re-enable the suspend and hibernation modes, run the command:
echo in | sudo -S systemctl unmask sleep.target suspend.target hibernate.target hybrid-sleep.target
I found this.
#!/bin/bash
# trap ctrl-c and call ctrl_c()
trap ctrl_c INT
function ctrl_c() {
echo "** Trapped CTRL-C"
for i in `seq 1 5`; do
sleep 1
echo -n "."
done
