I added an item to the context menu but I have a little problem with this script, I can't pass it the file(s) notepadqq needs to open:
import os
import urllib
from gi.repository import Caja, GObject
class ColumnExtension(GObject.GObject, Caja.MenuProvider):
def __init__(self):
pass
def menu_activate_cb(self, menu, file):
os.system("notepadqq pid=$!")
def get_file_items(self, window, file):
item = Caja.MenuItem(name='NotepadMenuProvider::Notepad',
label='Edit with Notepadqq',
tip='',
icon='')
item.connect('activate', self.menu_activate_cb, file)
return item,
