I'm building a simple Caja-Python extension and would like to show an "are you sure" messagebox before deleting files. There is no example in this repository.
Any suggestions?
Any suggestions?
Possibly some form of this?:
I'm looking for a messagebox (GUI).
I found the answer for a Caja-Python extension script in ~/.local/share/caja-python/extensions/script.py
def menu_activate_cb(self, menu, files):
dialog = Gtk.MessageDialog(
parent=None,
flags=0,
message_type=Gtk.MessageType.QUESTION,
buttons=Gtk.ButtonsType.YES_NO,
text="Are you sure?",
dialog.format_secondary_text("WARNING: This cannot be undone!")
response = dialog.run()
dialog.destroy()
if response == Gtk.ResponseType.YES:
print("QUESTION dialog closed by clicking YES button")
elif response == Gtk.ResponseType.NO:
print("QUESTION dialog closed by clicking NO button")
