Ive been trying to find source code or examples on how to make a Menu applet in python for mate… Im starting to wonder if its not possible, because the libraries i did find which were from 2010 had dead site links. Any example code anyone can share?
Keep in ming that you need to know :
Python2 / Python3
GTK 2 for Mate Gtk 2 and Gtk 3 for Mate Gtk 3 .
For a better undestarding I am gonna walk you thought the code .
testapplet.py
""" This decides the python interpreter (Better use python2 and python3 since both versions of python may be installed and difirent sysems have difirent versions set as default) """
#!/usr/bin/env python
# Here we import GTK's introspection module
import gi
# Here we specify the major version of Gtk . (Change to 3.0 if you have GTK 3 version of mate)
gi.require_version("Gtk", "2.0")
# Finaly we import Gtk and MatePanelApplet modules
from gi.repository import Gtk
from gi.repository import MatePanelApplet
""" This is the applet fill method . It is used for the actual applet structure . Everything that you create a Gtk.ActionMenu , Buttons and etc. should go here """
def applet_fill(applet):
# you can use this path with gio/gsettings
settings_path = applet.get_preferences_path()
# Here we create a Gtk.Label
label = Gtk.Label("My MATE applet in Python")
# this tells the applet to add the created label to the panel.
applet.add(label)
# this tells the applet to show all gtk widget created in the process (Couse every Gtk widget has to be shown)
applet.show_all()
# This is the factory method in this function we are getting the applet iid and if it is not TestApplet to return false
def applet_factory(applet, iid, data):
if iid != "TestApplet":
return False
applet_fill(applet)
return True
""" In this function basicly we are telling mate panel to initialize the applet if the Factory method returns true.
this function is from MatePanelApplet module"""
MatePanelApplet.Applet.factory_main("TestAppletFactory", True,
MatePanelApplet.Applet.__gtype__,
applet_factory, None)
Now for org.mate.panel.TestApplet.mate-panel-applet . This files tells the id of the applet . Its main module testapplet.py location , the iid . The name wich is gonna be displayed in the Panel add dialogue window and the comment to it .
The last is a dbus service file . org.mate.panel.applet.TestAppletFactory.service . This file calls the main method and the Factory file (previous file we mentioned).
