Thanks for that Steve. It looks very interesting and is a nicely designed board. It goes way beyond what I was thinking about.
I saw a rather simpler affair, which is purely a reset switch, consisting of two pins of 2.54mm pin strip and a reset computer cable. The two pins are soldered into the Run header on the Pi 2 board (It’s in a different place on the Pi board and only on Revision 2 Pi boards. It’s also called P6). Once soldered, attach the reset connector.
When the Pi 2 has been closed down by the OS (UM in my case), it is in a shutdown or halt state but with the power still connected. A momentary press of the switch attached to the computer reset cable, will wake up the Pi 2.
I must admit though, the additional functionality of the solution in the video you posted is interesting!
On the performance of the Pi 2 with UM, I am very impressed. I’m just at the stage of playing with this at the moment, but Open Office 5.0 runs very nicely.
Have you seen the PiNet project at http://pinet.org.uk ?
