Really need help with my Brother hl-2240 printer question
Not being able to print anything is quite an impediment.
With my memory problems, writing or printing things is pretty important.
If I am irritating folks with my questions, please let me know with details.
Thanks
Vielen Dank
Andy what exactly is your problem with your Brother printer?
I have a Brother MFC-J480DW printer and other than Parrot security (which is all sandboxed) I have never had a problem installing it.
Go to the Brother help center. Find your printer and download the correct driver package to Downloads.
Extract the drivers. I am not good with the terminal so use engrampa to do that.
Then in the terminal < cd Downloads >
Enter your model number. here is mine: model no. MFC-J480DW
It should then start to install, then it will ask you:
Will you specify the Device URI? [Y/n] -> answer n
Test Print? [y/N] -> answer y
Then you should be able to go to printers and set it as your default printer
