Recorder 1(raspberry )
Hi
I am using Raspberry Pi 3.
As I turn on and boot up my Raspberry Pi 3, i noticed that there is “Recorder 1( raspberry )” on my screen.
How do I disable them and what it is use for???
Hi
Please provide a screenshot (use PrintScr key) so we understand what you’re talking about.
Cheers
I am also having the same problem.
While installing opencv on raspberry pi, when the 'upgrade' step completed, I rebooted the module. Now it is showing the "Recorder 1 (raspberry) " on screen.
