it’s very cool there is a bulk rename feature. I used to install Thunar for that. Now, it would be very cool, if it remembered all (!) the settings, or if there was a checkbox to enable saving all settings for the next time. By all settings I mean that it shouldn’t have one checkbox that only acts for the function that is currently selected (replace, insert, remove or change case). Alternatively there should be five checkboxes: One for all next to four others for each single thing, all five visible at all times, independently of the selected function.
