Hi!
How remove default applications entries permanently from Mate CLASSIC menu?
I can de-select it via menu-editor but the files are then as .undo files
stored in "/home/user/.local/share/applications"
When I delete the .undo files, then the default application entries came back.
I want a clean applications folder and not duplicates and triplicates
entries.
Which files must I edit?
??? files in:
/home/user/.config/mate-menu
/home/user/.config/menus
/usr/share/applications
Please help, thanks!
