This problem has bugged me know for almost a year. Had Nuke NC installed, uninstalled it but the icons remain in my Applications>Graphics menu
(attached)
How do I get rid of these?
Ubuntu (Mate) 18.04.1 LTS
(attached)
I think you do the following:
Open Caja. Select Edit Preferences and when the File Management Preferences dialog box opens, look in the extensions tab. Uncheck any that don’t suit you.
Press <Alt>+<F2> then type mozo to open Main Menu editor.
You can find applications here:
and disable unneeded by unchecking checkmarks.
