Hi Everyone
I would like to rename the ethernet interface into Eth0 instead of enxMACADRESS. We project to use RPI3 and Ubuntu mate as a base for embedded devices of about 100unities. In order to not rewrite all of the script files that need to access ethernet I would like call the interface with a unique name for all devices.
I’ve seen that /etc/udev/rules.d/70-persistent-net.rules can be modified to achieve this. However the Mac address needs to be defined explicitly this the file can not be the same for each devices.
Any idea to solve that?
Regards
