2/20/19 I just found out that
The repository 'http://downloads.sourceforge.net/project/ubuntuzilla/mozilla/apt all Release' is not signed.
How can I get it signed?
remove the ppa and reinstall it. How to remove PPA
Then try to reinstall it.
I did so.
I got the key added.
It looks like firewall blocking port `11371` which is used by gpg. Force it to use port 80 to get gpg key.
sudo apt-key adv --recv-keys --keyserver hkp://keyserver.ubuntu.com:80 C1289A29
However,
sudo apt-get install seamonkey-mozilla-build
E: Unable to locate package seamonkey-mozilla-build
Could you or someone download the 64 bit Seamonkey build and send me a link to dropbox?
did you sudo apt update ? I just added the repo to my /etc/apt/sources.list, added the key, did update, and was able to install seamonkey-mozilla-build ...
Yes I did sudo apt update.
I got it installed.
I found the debian package here
https://sourceforge.net/projects/ubuntuzilla/files/mozilla/apt/pool/main/s/seamonkey-mozilla-build/
