I am running 15.04 on a raspberry pi. During installation I created a username and a password. Like a dummy I have forgotten the password. Is there a way to reset the password? Or add a new user whose password I will paint on the office wall?
if you have the same normal Ubuntu menu on Raspi, then follow the info here:
http://www.psychocats.net/ubuntu/resetpassword
and:
https://help.ubuntu.com/community/LostPassword
Hope it helps!.
The UbuntuMATE for RPi 2 does not show any GRUB menu as you can have it on PCs.
Thus, not sure how this can be activated on a RPi 2 device when booting up.
Try this:
Hi
I recently had the same problem how ever I didnt forget just my screen locker was on so I put it in my password but is says it wrong, I log in as guest and make sure my pass is correct it is⦠after doing some googling I see that people had the same problem and that is the keyboard layout/language anyways tried every language like US, CA etc and still it wont work. And the above tut did not work also to note I am ising berry boot. I need help ASAP please.
Cheers, mate. This definitely hepls
@wolfman yay helped me now too, when i forgot the password i had setup for moms Raspberry Pi 3 i am gonna send to her tommorow
