I installed Ubuntu Mate 24.04 yesterday and all went well except my AltGr key seems dead. (I need it for all sorts of special characters I use for my job)
Oddly it works fine in Featherpad which is the only app on this machine that didn't come on the MATE ISO, but it is dead in Pluma, LibreOffice, Firefox, etc.
I've tested just now the use of AltGr key combinations in an (Virtualbox) VM running a fresh install of Ubuntu MATE 24.04 LTS ("Noble Numbat") - the virtualization host machine is a laptop computer running Ubuntu MATE 22.04 LTS ("Jammy Jellyfish") - and the "ALT GR" key combinations are working well for me in "Pluma", "LibreOffice Writer" and "Mozilla Firefox". For instance, pressing the ALT GR key together with the E key shows the € (Euro currency sign), as expected.
Additional information about my setup: in the "Keyboard" application (available by hovering over the "Ubuntu MATE Menu" -> "Preferences" -> "Keyboard"):
If I click on that "Keyboard" menu option, then the "Keyboard Preferences" window opens. If I then click on the "Layouts" tab of that window, I can see that I'm using a "Portuguese" keyboard layout and the "Keyboard Model" is a Generic 105-key PC":
Although the "Alt Gr" key combinations are working well for me in this Virtual Machine, this reminds me that I haven't yet completed the "Language Support" in this VM. So, if I go to the Ubuntu MATE Menu -> "Preferences" -> "Language Support":
@Spider : Maybe it's worth trying to check the "Language Support" in your case, complete it (if you haven't done that already), and then reboot to see if it helps in your case? As I've written, in my case, the "Alt Gr" key combinations were working well, even without completing the "Language Support", but I see no harm in trying to do that.
I have a similar problem - AltGr seemed to stop working after upgrade Kubuntu 22.04 -> 24.04; closer examination shows it actually produces TWO characters - the correct one is preceded by ESC (ASCII 27), for example AltGr-a should render Polish character Ä… (aogonek), but instead generates ESC Ä… which breaks most (but not all apps). You can verify if your problem is the same by using cat command in konsole, then typing something with AltGr - if you see ^[ before each character, it represents ESC.
I checked my settings (dutch + dutch keyboard which also needs AltGr for certain characters).
In my case AltGr does not generate an extra ESC and does exactly what it is supposed to do.
So I think it's either a bug that is limited to certain languages (keyboard layouts) or your setup has one or more override options enabled (see keyboard preferences -> options).
If no override options are enabled then it's a bug.
It happened before, see this:
and this
You probably want to file a bug too, so use that site to do that.
Thanks for your reply. I know a bit more now - I have done a fresh install of 24.04 to a separate disk, and the system booted from that disk does not show the mentioned problem, so apparently it is caused by some "leftovers" from the upgrade (my system started as 14.04 LTS and has been upgraded to a new LTS version every two years since…); I'll have to investigate further to find the root cause.
Another possibility is that the compose key has not been set up. You can check this by opening the Keyboard Preferences dialog. Select the Layout tab, and then click the Options button. This opens the Keyboard Layout Options dialog. Scroll down the list to the “Position of Compose key” entry. Click the expander arrow to the left of this entry. On my current laptop with UM 24.04.3, none of the options under this entry are selected, not even Right-Alt; but then, I use a US layout and write in US English so I seldom have need to compose a special character.
If you’re still having trouble entering special characters, you could try checking the box for Right-Alt under this entry and see whether that now allows you to enter (compose) special characters.
Trying to follow the issue, but just not getting it.
My own keyboard layout shows the following:
I don't see AltGr anywhere (for CAN fr/en, US en, UK en). Is that a special for other countries only?
What I have noticed, possibly similar problem even if not identical, my left-sideAlt cannot be used. (Not sure ... but suspect it came with upgrade last year of my Kernel from 5.??? to 6.??? on UM22.04 )
I can only use right-sideAlt with PrtSc in order to trigger that action. For me, this is not a drop-dead issue and am OK with my status quo.
Yes. On, for instance, dutch keyboards it is the right-side Alt key that is named Alt Gr which works like a 2nd level shift.
On those keyboards you usually have the € symbol on the same key as the 5
so shift5 gives you %
and Alt Gr5 gives you €
I'm using a US keyboard on most of my gear, but to compose characters like Ç , è , á, €, £, etc I have set the right Alt key as a compose key.
On keyboards with an Alt Gr key you can redefine that key the same way and it allows for a much wider range of characters to type than the default behaviour of that key.
EDIT: My stinkpad T420 has a dutch keyboard with the € on E (and a lot more 3rd level keys than usual). See below:
