Upgraded from previous release (via command line, using “sudo do-release-upgrade”. Now my Pi 3 reboots every 5 minutes.
Does anyone else have this problem (and hopefully a solution) ?
Thanks,
Andy
Thanks,
Andy
Hello, welcome!
The Raspberry Pi version isn’t supposed to be upgraded. The kernel is different to that of the desktop edition and the upgrade has left your Pi running the 15.10 kernel instead of the one used in 16.04).
You could try manually updating the kernel:
sudo rpi-update
Really, it’s not recommended to upgrade the Raspberry Pi version across release versions as mentioned here:
OK, but surely when I logged-in and it told me to run the upgrade, then that message should be suppressed…
Cheers,
Andy
