Hi all. I'm having a slight problem as I can't work out how Chrome is auto-starting at boot / restart.
I've looked at the Startup Applications (
no signs ), Complete removal of chrome and re-install.
Can't see any option in Chrome settings.
Thanks..
olek
30 September 2020 18:25
2
Hi @Kwales66
Maybe try to disable that :
Thanks. It was already disabled.
olek
1 October 2020 11:10
4
Is Chrome set up as your preferred browser inside mate preferred applications ?
Maybe one of your apps is trying to open the web browser at startup. Try to change your preferred web browser to firefox and restart to see what will happen
Hi - Tried that even though Chrome wasn't set to my default before.
Even uninstalled chrome through mate welcome/browsers and then re-installed.
Chrome still starts up.
Hmmm. Maybe I'll try a restore from a few days ago.
Just tried a full restore from Timeshift and Deja. Sill the same.
Possibly Chrome - Oh well I can live with this for now.
Thanks
olek
1 October 2020 15:15
7
Can you check inside your bashrc ?
cat ~/.bashrc | grep chrome
and also here :
ls .config/autostart/
We will figure out
Results :
kurt@hal-12:~$ cat ~/.bashrc | grep chrome
kurt@hal-12:~$ ls .config/autostart/
blueman.desktop mate-optimus.desktop snap-userd-autostart.desktop
expressvpn-agent.desktop onboard-autostart.desktop ubuntu-mate-welcome-autostart.desktop
geoclue-demo-agent.desktop orca-autostart.desktop ubuntu-report-on-upgrade.desktop
magnus-autostart.desktop org.gnome.DejaDup.Monitor.desktop variety.desktop
mailnag.desktop print-applet.desktop
mainline.desktop redshift-gtk.desktop
kurt@hal-12:~$
olek
2 October 2020 07:10
9
It can be many reasons ...
I found this link that can help you searching :
http://ubuntuhandbook.org/index.php/2019/06/list-all-startup-applications-services-in-ubuntu-18-04/
It will list you all starting applications include system (hidden) ones.
I hope you will find it out there and slove your issue.
I tried disabling every startup item but Chrome still auto starts.
Also created a new test account. Chrome doesn't startup.
Do you happen to know if the startup process is logged and if so which one will tell me what's happening?
Finally Solved it. Removed google chrome - in the end......
