I installed UM 16.04 on two PCs. One I have no issue running “sudo caja”, but the other I get the following notice:
** Message: Initializing gksu extension...
Initializing caja-open-terminal extension
Initializing caja-main-menu extension
/usr/lib/python2.7/dist-packages/gi/overrides/Gtk.py:50: RuntimeWarning: You have imported the Gtk 2.0 module. Because Gtk 2.0 was not designed for use with introspection some of the interfaces and API will fail. As such this is not supported by the pygobject development team and we encourage you to port your app to Gtk 3 or greater. PyGTK is the recomended python module to use with Gtk 2.0
warnings.warn(warn_msg, RuntimeWarning)
sys:1: PyGIWarning: Caja was imported without specifying a version first. Use gi.require_version('Caja', '2.0') before import to ensure that the right version gets loaded.
sys:1: Warning: /build/glib2.0-7IO_Yw/glib2.0-2.48.1/./gobject/gsignal.c:2635: instance '0x563d170f5180' has no handler with id '15728'
sys:1: Warning: /build/glib2.0-7IO_Yw/glib2.0-2.48.1/./gobject/gsignal.c:2635: instance '0x563d17522500' has no handler with id '15805'
sys:1: Warning: /build/glib2.0-7IO_Yw/glib2.0-2.48.1/./gobject/gsignal.c:2635: instance '0x563d16ef9480' has no handler with id '15812'
sys:1: Warning: /build/glib2.0-7IO_Yw/glib2.0-2.48.1/./gobject/gsignal.c:2635: instance '0x563d17654960' has no handler with id '15777'
sys:1: Warning: /build/glib2.0-7IO_Yw/glib2.0-2.48.1/./gobject/gsignal.c:2635: instance '0x563d173e3ee0' has no handler with id '15784'
sys:1: Warning: /build/glib2.0-7IO_Yw/glib2.0-2.48.1/./gobject/gsignal.c:2635: instance '0x563d174ce680' has no handler with id '15791'
sys:1: Warning: /build/glib2.0-7IO_Yw/glib2.0-2.48.1/./gobject/gsignal.c:2635: instance '0x563d1752a560' has no handler with id '15798'
sys:1: Warning: Source ID 69 was not found when attempting to remove it
sys:1: Warning: Source ID 70 was not found when attempting to remove it
sys:1: Warning: Source ID 71 was not found when attempting to remove it
Not sure why I get this on one PC and not the other. Any solution?
