With 17.10 beta, with Munity interface (hud + global menu), when I try to launch any header bar app like gnome-calendar it produces following error:
#033[31mvoid DBusMenuImporter::slotGetLayoutFinished(QDBusPendingCallWatcher*)#033[0m: "No such interface 'com.canonical.dbusmenu' on object at path /org/ayatana/bamf/window/69206023"
For some apps there is no menu on the panel. Even headerbar apps produces a vertical menu on the panel. And after launching the app I get even more errors:
Oct 7 12:45:03 artful-dev compiz[1664]: WARN 2017-10-07 12:45:03 <unknown>:0 Failed to fetch path: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.application' on object at path /org/ayatana/bamf/application/1132601836
Oct 7 12:45:03 artful-dev compiz[1664]: message repeated 7 times: [ WARN 2017-10-07 12:45:03 <unknown>:0 Failed to fetch path: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.application' on object at path /org/ayatana/bamf/application/1132601836]
Oct 7 12:45:03 artful-dev compiz[1664]: WARN 2017-10-07 12:45:03 <unknown>:0 Failed to fetch xid: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/62914572
I am not sure which component is responsible (may bamf-daemon ?), so I really file a bug at this point. But can anyone reproduce it?
