I am still helping my friend with his small office and the great many document files that he has stored in a single partition in directories by client names.
During his time using that 'other' OS I had made this happen on a schedule using a simple tool that copied the entire file structure, ignoring existing files & adding new/changed files to a collection of numbered USB sticks, which got swapped out to store off premises in case there was some sort of disaster at his little home office.
Since he felt very well protected with this setup, I would like to make this happen again for him now that he is a Linux user.
Trouble is - searching for backup answers centering upon USB brings a bazillion vague & unrelated results.
No protection or compression is needed or desired - just straight up file copying with the user only needed to change the USB stick regularly.
So - for instance - can Déjà Dup do this with the stick getting changed with no other user actions needed - will it just find the changed stick on its own somehow, or ??
Sbackup is by now quite old & seems abandoned, so no luck there, I think.
The luckyBackup docs make no mention of this either.
With that 'other' OS all I had to do was make sure that the sticks always got the same drive letter & so I now wonder if I make them all have the same name (Sandisk or whatever) might that be enough to 'fool' a backup util to find & use all the different sticks ?? (They are each labeled outside with a number).
I hope someone here will point me in the right directions for this as I am quite used to Linux full system backups, but not file by file ones.
This query has also been posted at Ask Ubuntu some days ago, but has drawn very little attention & no answer(s) AS YET.
Thanks in advance for any help with this.
