When trying to enter my password for 1Password Anywhere in Firefox, I get a notice that a “script” is not responding. I’m assuming this is referring to Javascript. I have ensured that IcedTea is installed and allowed to run in all the ways that I know how. As far as I know, this is the only page I am having difficulty with. I believe it is more to do with Dropbox than 1Pass in itself. Any suggestions on how I can get this working? I’m kind of DOA without 1Pass.
If you only want dropbox check this link:
Or this maybe help more.
https://support.mozilla.org/en-US/questions/949489
It may be a bug with the program, try if this affects another web browser (e.g. Chromium) and/or consider filling a report.
I will address all suggestions in order. Thanks for the attempts:
The only reason I have Dropbox is for 1PasswordAnywhere. I wouldn’t have Dropbox at all otherwise.
There is no “social fixer” addon in my Firefox.
Doesn’t work with Midori either and I WISH Chromium was available for PowerPC.
Other things I tried were:
Starting Firefox in safe mode with all extensions disabled.
about:config > dom.max_script_run_time > set it to 20 and then 30 as suggested here:
https://support.mozilla.org/en-US/kb/warning-unresponsive-script
I also tried adding the YesScript extension and blacklisting as mentioned later on. -
about:config > javascript.options.baselinejit to true. It was already set to true.
https://discussions.agilebits.com/discussion/22463/1passwordanywhere-causing-unresponsive-script-when-trying-to-unlock-in-firefox-24
May be time to consider migrating to KeePass if I can’t get this sorted. Although, this is a totally experimental PowerPC, “Just to say I can run Linux on it” machine anyhow. It’s nowhere near a daily driver so, I guess it’s not that big a deal.
My guess is that javascript in Firefox on PPC is just not fast enough due to the older chip and much less optimization in the javascript engine. I don’t think Spidermonkey (Firefox’s javascript engine) includes a JIT compiler for PPC, so it’s just using the interpreter, which is a whole lot slower for this sort of thing.
(Edit: Not having a version of their javascript engine V8 on PPC is the reason there’s no Chromium, so at least Firefox can work for most things.)
