i bump into this error when i boot for the first time, first it shows ACPI PCC probe error, then i disable graphical boot (that logo booting screen) then i saw that line keeps running over and over again like this:
Running /scripts/local-block…done
and then it says give up waiting on system and busybox started and the keyboard is nor responding but the pc did not freeze as it can detect and log USB port activities
more info here: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=790560
note this is not excatly what i have but this is the closest one i can find on the internet
HELP ME
Unless you're trying to run Ubuntu MATE on a Sparc machine I doubt this bug report will help much.
Please start by collecting information on the machine by booting the live USB and running the command:
inxi -ACDSIGMN
Run that command in a terminal open using CTRL+ALT+T and provide the output through pastebin for example.
Next please give informations about the procedure you used to install the system.
i dont know how to pastebin so im just gonna paste the whole thing here:
System: Host: ubuntu-mate Kernel: 4.4.0-21-generic x86_64 (64 bit)
Desktop: MATE 1.12.1 Distro: Ubuntu 16.04 xenial
Machine: Mobo: ASRock model: H87M Pro4
Bios: American Megatrends v: P1.20 date: 05/03/2013
CPU: Quad core Intel Core i7-4770 (-HT-MCP-) cache: 8192 KB
clock speeds: max: 3900 MHz 1: 3400 MHz 2: 3399 MHz 3: 3400 MHz
4: 3403 MHz 5: 3403 MHz 6: 3400 MHz 7: 3400 MHz 8: 3400 MHz
Graphics: Card: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa)
Resolution: [email protected]
GLX Renderer: Mesa DRI Intel Haswell Desktop
GLX Version: 3.0 Mesa 11.2.0
Audio: Card-1 Intel 8 Series/C220 Series High Definition Audio Controller
driver: snd_hda_intel
Card-2 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.4.0-21-generic
Network: Card: Intel Ethernet Connection I217-V driver: e1000e
Drives: HDD Total Size: 568.0GB (0.3% used)
ID-1: /dev/sda model: WDC_WD5000AAKX size: 500.1GB
ID-2: USB /dev/sdb model: DataTraveler_120 size: 4.0GB
ID-3: USB /dev/sdc model: Flash_Drive size: 63.9GB
Info: Processes: 239 Uptime: 0 min Memory: 358.4/7641.7MB
Client: Shell (bash) inxi: 2.2.35
now for the procedures:
- fire up my usb drive
- choose the first option or try ubuntu MATE and not installing
- try it out
- install
- it just auto reboots
- ACPI PCC probe failed
bump
bump
bump
bump
bump
pls someone look at this
Have you tried changing any acpi options?
Is this a mac (apple)?
https://ubuntuforums.org/showthread.php?t=1613132
