For some reason, I am not able to use my microSD Card reader on my Ubuntu MATE 20.10 laptop. I restarted the OS multiple times and the device still does not appear when attempting to be in use.
Laptop - Thinkpad E595 Ryzen 5 3500U
SD Card readers are notoriously prone to hardware problems -- if nothing else, the pins that are supposed to contact the card rarely are bent enough at the factory. That said, I don't suggest you bend the pins just yet; but first, unplug the card one more time and re-insert it into the reader. If that still doesn't work, upload the output of the command:
dmesg
...in a post here.
Believe me, half the time I can't read SD or microSD cards on my hardware -- it's always (so far!) been caused by faulty hardware or the pins being dirty.
Having issues uploading the output.... Is there something I can pipe in to condense the output?
You can upload the output the Pastebin and paste the link here
sudo dmesg --clear will clear the output to focus only you need
Plug the card
sudo dmesg it will print only the messages arrived after you have cleared the logs.
