Just upgraded from a pre-snap release to 22.04.
I found /home/m9ke/snap/snapd-desktop-integration/B3/Documents contains links to every file in my Documents directory.
And I found that deleting or renaming changes made to the files in the snap directory are automatically applied to the files in my Documents directory.
Example: deleted a file in the *B3 directory: it disappeared from my Documents folders. Same if I renamed the file, the filename changed i my Documents directory.
I'm aware of the differing points of view around snap and for the moment I am remaining agnostic.
This mirroring of my Documents directory in the B3 directory concerns me, I understand storage is cheap--that's not the concern.
The concerns are: 1-potentially un-needed complexity; and 2-I did not know that my Documents directory would be linked to file by file until after the install (mostly my bad).
I would greatly appreciate any comments: why is are links to every file being created? Does snap really need to do this in order to function?
Thanks in advance for the education!
Mike
