I would like to use this in a script, but it needs Ctrl D to send it.
ssmtp [email protected] < Test_Email.txt
Is there a way to send ctrl D to it and have it execute?
Ctrl-D is an EOF character.
It tells where is the End Of File
In the scripts it's used like this:
cat << EOF
Here
is some
text.
EOF
From the manual man ssmtp it looks like -t option is what you are looking for.
From here sSMTP - ArchWiki it looks like message has a header and content.
CONTENT="I would like to use this in a script, but it needs Ctrl D to send it."
ssmtp -t << EOF
To: [email protected]
Subject: fixit asking for help
$CONTENT
Cheers,
fixit
EOF
This works, but I get an error message.
/home/andy/bin/Send_Email.sh: line 18: warning: here-document at line 8 delimited
by end-of-file (wanted `EOF')
#!/bin/bash
# Ubuntu_Mate 18.04 LTS
ssmtp -t << EOF
$CONTENT
Cheers,
fixit
EOF
EOF must be at the begining of the line. Remove the leading spaces in front of EOF
[code]#!/bin/bash
CONTENT=“I would like to use this in a script, but it needs Ctrl D to send it.”
ssmtp -t << EOF
$CONTENT
Cheers,
fixit
EOF[/code]
No errors, but only recipient and subject came thru?
from here sSMTP - ArchWiki
Note: When using mail interactively, after typing the Subject: subject and other headers, hit enter twice, and then type the body. Hit Ctrl+d on a blank line to end your message and automatically send it out.
Maybe there need to be one or two empty lines between the header and the content (message body).
After entering 2 blank lines under Subject, it now works.
I usually install mutt and use that:
mutt -s “Subject” -a /path/to/attachment – [email protected] < /path/to/body.txt
Just to give an alternative
