I am in the midst of a fresh install of UMate 19.10 on AMD64 system.
I created /boot (EFI) / and /home on a 512GB M.2 drive, all is well.
I created a 32GB /SWAP on a 1TB SSD, all is well.
I am trying to create a storage drive with the remainder of the 1TB SSD drive and I can't access it, even though I can see it in /mnt/storage (I created via terminal). I can't make a link to it, or have it show up as a separate drive space on Caja.
Since this is an Asus laptop, all updates, including BIOS and kernel have been done.
All help would be appreciated.
~Jackie
