Simple pdf editor
I have been using Atril to edit a housing document that I am filling out.
(I would like to get the 38 page document turned in as soon as I can.)
The fonts are different sizes for many of the boxes. I did a search for editors and found Okular etc.
I just need a simple pdf editor where the fonts that will look readable.
Where the fonts do not go from 5 to 25. :slight_smile:
I have seen what you are experiencing. I use LibreOffice Draw, which does allow some control of font sizes in boxes that you are filling in.
As an FYI, to sign a PDF using a pointing device, Xournal++ works well.
Good luck with your large document.
Thanks. The PDF is a "fillable" document. I opened it using LibreOffice Draw.
I could not find how to get to the first page.
For now, I will continue to use Atril to finish filling out the document.
Then I will print one page at a FedEx store and see how it looks.
If it looks readable, then I am good to go.
From my experience, Okular is more of a "mark-up" tool than it is an editor. There is no function/feature that allows you to perform editorial corrections ... like replacing a mis-typed letter, or adding a missing "newline".
As for "major" edits on a PDF form, to maintain style, positionning, etc., I haven't come across any that works.
Even LibreOffice Draw, it may be able to rebuild a printable PDF that keeps the original appearance, but does not seem to correctly handle the "editable" functionality of modifiable PDFs, à la Adobe.
Linux version of Foxit.
I prefer using Libre Office Draw. But Master PDF editor may work.
The snap store offers onlyoffice-desktopeditors. For editing PDF documents it has more capabilities than any other free non-web solution that I've found. The trade-off is that the learning curve is higher.
I used master pdf editor, since many years, and only the version 4.3.89 as it's full features and free.
The only real drawback I have found with OnlyOffice which I agree is probably the best replacement for MS office is that it only opens the whole suite that seems to take forever. You can't just open a writer, calc or .pfd instance which would be a lot quicker. At least not the last time I used it which has been awhile.
The latest version of Master pdf editor is free-for-trial, but it adds a watermark. OnlyOffice does not. Other than that advantage, I think it's a matter of preference. Jymm has a valid point, too, about the load time.
