Sisimedia video support please and overheat problem in 16.04
Only rpm based distros like mageia or openmandriva and pclinux os supports sisimedia video driver
I can’t login 16.04 because latest kernel is overheating cpu
add option too choose kernel 4.1 with long term support please. Here is my problem:
https://forums.mageia.org/en/viewtopic.php?f=8&t=11043
I solved my problem in kernel 4.1 LTS but 4.4 don’t.
Not sure I understand you.
Did you try Kernel 4.1 with Ubuntu MATE 16.04?
Are you sure this is a kernel issue and not overheat caused by a rogue program such as gvfsd-smb?
Hi @Daniel_Paim,
try running "dpkg" (network cable connection required!) per the update guide:
See also:
Does Ubuntu 16.04 option to choose kernel 4.1 LTS during installation?
No it’s not an option. You always get the 4.4 kernel after install.
I need kernel 4.1 LTS please
I solved my overheat problem. Does VESA mode supports 2D acceleration? Sisimedia Does. Bodhi Linux users compiled for deb. I will thy this VESA mode.
