Sitecom ac600 wifi adapter
Hi guys!
Im new to RPi2 and linux, and im trying to get this sitecom ac600 usb wifi adapter to work on mate 15.10.1. I tried to follow the steps described in this guide:
http://louwrentius.com/getting-the-sitecom-ac600-wi-fi-adapter-running-on-linux.html
So this guide tells us we have the Mediatek MT7610U
But i cant 'make'. From what i understand is that i need the source files. But I have no idea how to obtain those.
I also looked at this method below
This guide is for the Ralink MT7601U unfortunately,
Is there some sort of magic combination of both methods that result in a working wifi adapter?
edit: I just found that i have the WLA-2104 (Sitecom | 25 years expertise in connectivity | Shop online), which is not the WLA-3100 as used above. Found this link:
Apperantly, my only hope is ndiswrapper. Lets see how this works. Il update when ill get stuck :wink:
What is the USB id of the adapter? Use “lsusb”.
It sounds like you're missing the programs to compile and build software. You'll need to temporarily connect with a wired connection to acquire these.
sudo apt-get update
sudo apt-get install build-essential make
Once you have make installed you can compile such drivers. The instructions you linked to require a tar.gz file to download which I'd presume contains source files, but I'm not too sure of the attitude of the author of the guide... :confused:
Rest assured, Linux isn't all scary compiling software from scratch. Some manufacturers are great and maintain drivers in the kernel, which means it'll work out of the box ... but there is a majority who don't create free (as in open source) drivers and we have to rely on community efforts to get them working. :frowning:
You'll also find that different brands may also have the same chipset.
Unfortunately, ndiswrapper only works for Windows XP drivers for the x86 architecture (PC, not ARM like the Pi), so this wouldn't work. :thumbsdown:
As @Dave_Barnes asks, if you provide us with lsusb from the terminal, we can verify which drivers you need.
Also make sure you have "Source code" marked in your repositories!:
lsusb:
Bus 001 Device 006: ID 24ae:2003
Bus 001 Device 005: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive
Bus 001 Device 004: ID 0df6:007a Sitecom Europe B.V.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Thus indeed the same as:
http://ubuntuforums.org/showthread.php?t=2264741
i do have access to the xp drivers (if usefull)
dmesg:
[ 1.913951] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.015011] usb 1-1.2: New USB device found, idVendor=0df6, idProduct=007a
[ 2.015039] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.015055] usb 1-1.2: Product: WLA-2104
[ 2.015072] usb 1-1.2: Manufacturer: Sitecom Europe BV
[ 2.015087] usb 1-1.2: SerialNumber: 00e04c000001
edit:
So this means indeed i have the rtl8811au chip. (Also found in xp drivers) Now i have found these:
http://www.linux-hardware-guide.com/nl/2014-09-17-edimax-ew-7811utc-ac600-usb-wifi-dual-band-802-11ac-5ghz-802-11n-2-4ghz
I tried the last one, but i when i try to make, as described in last step:
root@RPI:/home/rpi/rtl8812au# make
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/4.1.15-v7+/build M=/home/rpi/rtl8812au  modules
make[1]: *** /lib/modules/4.1.15-v7+/build: No such file or directory.  Stop.
Makefile:1051: recipe for target 'modules' failed
make: *** [modules] Error 2
indeed in /lib/modules/4.1.15-v7+/ no build folder/file while when i run apt-get install build essentials im fully updated (and i did like wolfman said)
Any ideas?
Try this:
remember im a linux newb :slightly_smiling:
first step of guide: install kernel headers ->
E: Unable to locate package linux-image-rpi-rpfv
E: Unable to locate package linux-headers-rpi-rpfv
what should i add in the sources.list?
or should i use ‘native headers’ which will end up in same error as above
Hi @Soppie,
go here and download the driver direct and then read the “Readme” that comes with the packge, if you are lucky it will download as a deb file and just open it with Gdebi, if not, post back!:
it downloads as a tar.bz2, unzipped all seperate files
from readme:
Driver lName:
rt2870.o/rt2870.ko
Supporting Kernel:
linux kernel 2.4 and 2.6 series.
Tested in Redhat 7.3 or later.
Ralink Hardware:
Ralink 802.11n Wireless LAN Card.
Description:
This is a linux device driver for Ralink RT2870 USB ABGN WLAN Card.
This is not the WLA-2104 / rtl8811au / 0df6:007a? (i really dont understand all the different names :p).
Sorry, wrong file, try this package and wait for one of the mods to help you install it, paste the complete readme please!:
DELETE THE OTHER FILE YOU DOWNLOADED!.
The other option is to download the Winblows driver and use “ndiswrapper”:
Very strange, readme indicates same chip?
* README
* Ralink Tech Inc.
* http://www.ralinktech.com
ModelName:
RT2870 Wireless Lan Linux Driver
Driver lName:
rt2870.o/rt2870.ko
Supporting Kernel:
Ralink Hardware:
Description:
Contents:
Makefile	        : Makefile
*.c					: c files
*.h					: header files
Features:
   This driver implements basic IEEE802.11. Infrastructure and adhoc mode with
   open or shared or WPA-PSK or WPA2-PSK authentication method.
   NONE, WEP, TKIP and AES encryption.
Build Instructions:
1> $tar -xvzf DPB_RT2870_Linux_STA_x.x.x.x.tgz
    go to "./DPB_RT2870_Linux_STA_x.x.x.x" directory.
2> In Makefile
	 set the "MODE = STA" in Makefile and chose the TARGET to Linux by set "TARGET = LINUX"
	 define the linux kernel source include file path LINUX_SRC
	 modify to meet your need.
3> In os/linux/config.mk
	define the GCC and LD of the target machine
	define the compiler flags CFLAGS
	** Build for being controlled by NetworkManager or wpa_supplicant wext functions
	   Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y'.
	   => #>cd wpa_supplicant-x.x
	   => #>./wpa_supplicant -Dwext -ira0 -c wpa_supplicant.conf -d
	** Build for being controlled by WpaSupplicant with Ralink Driver
	   Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=n'.
	   => #>cd wpa_supplicant-0.5.7
	   => #>./wpa_supplicant -Dralink -ira0 -c wpa_supplicant.conf -d
4> $make
	# compile driver source code
	# To fix "error: too few arguments to function ¡¥iwe_stream_add_event"
	  => $patch -i os/linux/sta_ioctl.c.patch os/linux/sta_ioctl.c
5> $cp RT2870STA.dat  /etc/Wireless/RT2870STA/RT2870STA.dat
6> load driver, go to "os/linux/" directory.
    #[kernel 2.4]
    #    $/sbin/insmod rt2870sta.o
    #    $/sbin/ifconfig ra0 inet YOUR_IP up
    #[kernel 2.6]
    #    $/sbin/insmod rt2870sta.ko
7> unload driver
    $/sbin/ifconfig ra0 down
	$/sbin/rmmod rt2870sta
CONFIGURATION:
RT2870 driver can be configured via following interfaces,
i.e. (i)"iwconfig" command, (ii)"iwpriv" command, (iii) configuration file
i)  iwconfig comes with kernel.
ii) iwpriv usage, please refer to file "iwpriv_usage.txt" for details.
iii)modify configuration file "RT2870STA.dat" in /etc/Wireless/RT2870STA/RT2870STA.dat.
Configuration File : RT2870STA.dat
# Copy this file to /etc/Wireless/RT2870STA/RT2870STA.dat
# This file is a binary file and will be read on loading rt.o module.
# Use "vi RT2870STA.dat" to modify settings according to your need.
# 1.) set NetworkType to "Adhoc" for using Adhoc-mode, otherwise using Infrastructure
# 2.) set Channel to "0" for auto-select on Infrastructure mode
# 3.) set SSID for connecting to your Accss-point.
# 4.) AuthMode can be "WEPAUTO", "OPEN", "SHARED", "WPAPSK", "WPA2PSK", "WPANONE"
# 5.) EncrypType can be "NONE", "WEP", "TKIP", "AES"
# for more information refer to the Readme file.
#The word of "Default" must not be removed
Default
CountryRegion=5
CountryRegionABand=7
CountryCode=
SSID=Dennis2860AP
NetworkType=Infra
WirelessMode=9
Channel=0
BeaconPeriod=100
TxPower=100
BGProtection=0
TxPreamble=0
RTSThreshold=2347
FragThreshold=2346
TxBurst=1
WmmCapable=0
AckPolicy=0;0;0;0
AuthMode=OPEN
EncrypType=NONE
WPAPSK=
DefaultKeyID=1
Key1Type=0
Key1Str=
Key2Type=0
Key2Str=
Key3Type=0
Key3Str=
Key4Type=0
Key4Str=
PSMode=CAM
FastRoaming=0
RoamThreshold=70
HT_RDG=1
HT_EXTCHA=0
HT_OpMode=1
HT_MpduDensity=4
HT_BW=1
HT_AutoBA=1
HT_BADecline=0
HT_AMSDU=0
HT_BAWinSize=64
HT_GI=1
HT_MCS=33
HT_MIMOPSMode=3
EthConvertMode=
EthCloneMac=
IEEE80211H=0
TGnWifiTest=0
WirelessEvent=0
MeshId=MESH
MeshAutoLink=1
MeshAuthMode=OPEN
MeshEncrypType=NONE
MeshWPAKEY=
MeshDefaultkey=1
MeshWEPKEY=
CarrierDetect=0
*NOTE:
	WMM parameters
			WmmCapable			Set it as 1 to turn on WMM Qos support
			AckPolicy1~4		Ack policy which support normal Ack or no Ack
								(AC_BK, AC_BE, AC_VI, AC_VO)
	All WMM parameters do not support iwpriv command but ¡¥WmmCapable¡¦¡¦,
	please store all parameter to RT2870STA.dat, and restart driver.
syntax is 'Param'='Value' and describes below.
@> CountryRegion=value
	value
		0: use 1 ~ 11 Channel
		1: use 1 ~ 13 Channel
		2: use 10 ~ 11 Channel
		3: use 10 ~ 13 Channel
		4: use 14 Channel
		5: use 1 ~ 14 Channel
		6: use 3 ~ 9 Channel
		7: use 5 ~ 13 Channel
	   31: use 1 ~ 14 Channel (ch1-11:active scan, ch12-14 passive scan)
@> CountryRegionABand=value
	value
		0: use 36, 40, 44, 48, 52, 56, 60, 64, 149, 153, 157, 161, 165 Channel
		1: use 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140 Channel
		2: use 36, 40, 44, 48, 52, 56, 60, 64 Channel
		3: use 52, 56, 60, 64, 149, 153, 157, 161 Channel
		4: use 149, 153, 157, 161, 165 Channel
		5: use 149, 153, 157, 161 Channel
		6: use 36, 40, 44, 48 Channel
		7: use 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 149, 153, 157, 161, 165 Channel
		8: use 52, 56, 60, 64 Channel
		9: use 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 132, 136, 140, 149, 153, 157, 161, 165 Channel
	   10: use 36, 40, 44, 48, 149, 153, 157, 161, 165 Channel
	   11: use 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 149, 153, 157, 161 Channel
@> CountryCode=value
	value
		AG, AR, AW, AU, AT, BS, BB, BM, BR, BE, BG, CA, KY, CL, CN, CO, CR, CY, CZ, DK, DO, EC, SV, FI, FR, DE,
		GR, GU, GT, HT, HN, HK, HU, IS, IN, ID, IE, IL, IT, JP, JO, LV, LI, LT, LU, MY, MT, MA, MX, NL, NZ, NO,
		PE, PT, PL, RO, RU, SA, CS, SG, SK, SI, ZA, KR, ES, SE, CH, TW, TR, GB, UA, AE, US, VE
		"" => using default setting: 2.4 G - ch 1~11; 5G - ch 52~64, 100~140, 149~165
@> SSID=value
	value
		0~z, 1~32 ascii characters.
@> WirelessMode=value
	value
		0: legacy 11b/g mixed
		1: legacy 11B only
		2: legacy 11A only         //Not support in RfIcType=1(id=RFIC_5225) and RfIcType=2(id=RFIC_5325)
		3: legacy 11a/b/g mixed     //Not support in RfIcType=1(id=RFIC_5225) and RfIcType=2(id=RFIC_5325)
		4: legacy 11G only
		5: 11ABGN mixed
		6: 11N only
		7: 11GN mixed
		8: 11AN mixed
		9: 11BGN mixed
	   10: 11AGN mixed
@> Channel=value
	value
		depends on CountryRegion or CountryRegionABand
@> BGProtection=value
	value
		0: Auto
		1: Always on
		2: Always off
@> TxPreamble=value
  	value
		0:Preamble Long
		1:Preamble Short
		2:Auto
@> RTSThreshold=value
	value
		1~2347
@> FragThreshold=value
	value
		256~2346
@> TxBurst=value
	value
		0: Disable
		1: Enable
@> NetworkType=value
	value
		Infra: infrastructure mode
       	Adhoc: adhoc mode
@> AuthMode=value
	value
		OPEN	 	For open system
		SHARED	  	For shared key system
		WEPAUTO     Auto switch between OPEN and SHARED
		WPAPSK      For WPA pre-shared key  (Infra)
		WPA2PSK     For WPA2 pre-shared key (Infra)
		WPANONE		For WPA pre-shared key  (Adhoc)
		WPA         Use WPA-Supplicant
		WPA2        Use WPA-Supplicant
@> EncrypType=value
	value
		NONE		For AuthMode=OPEN
		WEP			For AuthMode=OPEN or AuthMode=SHARED
		TKIP		For AuthMode=WPAPSK or WPA2PSK
		AES			For AuthMode=WPAPSK or WPA2PSK
@> DefaultKeyID=value
	value
		1~4
@> Key1=value
    Key2=value
    Key3=value
    Key4=value
	value
		10 or 26 hexadecimal characters eg: 012345678
        5 or 13 ascii characters eg: passd
    (usage : "iwpriv" only)
@> Key1Type=vaule
    Key2Type=value
    Key3Type=vaule
    Key4Type=vaule
    value
		0   hexadecimal type
		1   assic type
    (usage : reading profile only)
@> Key1Str=value
    Key2Str=value
    Key3Str=vaule
    Key4Str=vaule
    value
		10 or 26 characters (key type=0)
		5 or 13 characters  (key type=1)
@> WPAPSK=value
	value
		8~63 ASCII  		or
		64 HEX characters
@> WmmCapable=value
	value
		0: Disable WMM
		1: Enable WMM
@> PSMode=value
    value
    	CAM			    Constantly Awake Mode
		Max_PSP		    Max Power Savings
		Fast_PSP		Power Save Mode
@> FastRoaming=value
	value
		0				Disabled
		1				Enabled
@> RoamThreshold=value
	value
		Positive Interger(dBm)
@> HT_RDG=value
	value
		0				Disabled
		1				Enabled
@> HT_EXTCHA=value (Extended Channel Switch Announcement)
	value
		0				Below
		1 				Above
@> HT_OpMode=value
	value
		0				HT mixed format
		1				HT greenfield format
@> HT_MpduDensity=value
	value (based on 802.11n D2.0)
		0: no restriction
		1: 1/4 £gs
		2: 1/2 £gs
		3: 1 £gs
		4: 2 £gs
		5: 4 £gs
		6: 8 £gs
		7: 16 £gs
@> HT_BW=value
	value
		0				20MHz
		1				40MHz
@> HT_AutoBA=value
	value
		0				Disabled
		1				Enabled
@> HT_BADecline
	value
		0				Disabled
		1			    Enabled <Reject BA request from AP>
@> HT_AMSDU=value
	value
		0				Disabled
		1				Enabled
@> HT_BAWinSize=value
	value
		1 ~ 64
@> HT_GI=value
	value
		0				long GI
		1				short GI
@> HT_MCS=value
	value
		0 ~ 15
		33: auto
@> HT_MIMOPSMode=value
		0				Static SM Power Save Mode
		1				Dynamic SM Power Save Mode
		2				Reserved
		3				SM enabled
	(not fully support yet)
@> EthConvertMode=value
	value
		dongle
		clone
		hybrid
@> EthCloneMac=value
	value
		xx:xx:xx:xx:xx:xx
@> IEEE80211H=value
	value
		0				Disabled
		1				Enabled
@> TGnWifiTest=value
	value
		0				Disabled
		1				Enabled
@> WirelessEvent=value
	value
		0				Disabled
		1				Enabled <send custom wireless event>
@> MeshId=value
	value
		Length 1~32 ascii characters
@> MeshAutoLink=value
	value
		0				Disabled
		1				Enabled
@> MeshAuthMode=value
	value
@> MeshEncrypType=value
	value
		NONE		For MeshAuthMode=OPEN
		WEP			For MeshAuthMode=OPEN
		TKIP		For MeshAuthMode=WPANONE
		AES			For MeshAuthMode=WPANONE
@> MeshWPAKEY=value
	value
		8~63 ASCII  		or
		64 HEX characters
@> MeshDefaultkey=value
	value
		1~4
@> MeshWEPKEY=value
	value
		10 or 26 characters
		5 or 13 characters
@> CarrierDetect=value
	value
		0				Disabled
		1				Enabled
MORE INFORMATION
If you want for rt2870 driver to auto-load at boot time:
A) choose ra0 for first RT2870 WLAN card, ra1 for second RT2870 WLAN card, etc.
B) create(edit) 'ifcfg-ra0' file in /etc/sysconfig/network-scripts/,
   edit( or add the line) in /etc/modules.conf:
       alias ra0 rt2870sta
C) edit(create) the file /etc/sysconfig/network-scripts/ifcfg-ra0
   DEVICE='ra0'
   ONBOOT='yes'
NOTE:
   if you use dhcp, add this line too .
    BOOTPROTO='dhcp'
*D) To ease the Default Gateway setting,
    add the line
    GATEWAY=x.x.x.x
Dongle/Clone Features:
A) Dongle mode:
   	Provides a 1-to-N MAC address mapping mechanism such that more than one PC behind the STA
   	can transparently connect to the AP.
B) Clone mode:
	Provides a 1-to-1 MAC address mapping mechanism.
	STA can use own MAC as SA MAC or
			use user desired MAC as SA MAC or
		    use source MAC of first packet coming from wired device as SA MAC.
	NOTE: In this mode, only the PC who own the specified MAC can connect to the AP.
C) Hybrid mode(Dongle+Clone):
D) Please refer to "Config STA to link as dongle mode..." in iwpriv_usage.txt for releated commands.
Have you tried the "Additional Drivers Tool"?:
