Since yesterday I have a problem running apt-get update with the official Skype repo enabled:
get:8 https://repo.skype.com/deb stable/main amd64 Packages [2.470 B]
Err:8 https://repo.skype.com/deb stable/main amd64 Packages
File has unexpected size (2248 != 2470). Mirror sync in progress? [IP: 23.210.253.5 443]
Hashes of expected file:
- Filesize:2470 [weak]
- SHA512:735e1846804a5546772b89ba61e151741e0c1b60ca43b76e8e0cf6bf9fd07e1e2bf14ee479fe333ce9f8e9d38f3a9dc30f27a6cc22cd94d40a65f918607c7eab
- SHA256:cd656d44eaf3e7a9d3e0e88854cd24a797d049271d52b61ae6a8c9cdc0aa9be9
- SHA1:e9c7c67a369ec42d5bc5427393baaa3292b7f368 [weak]
- MD5Sum:14462be88a636471854935b4add65b30 [weak]
Release file created at: Mon, 24 Sep 2018 14:36:19 +0000
Fetched 87,7 kB in 5s (16,1 kB/s)
Reading package lists... Done
E: Failed to fetch https://repo.skype.com/deb/dists/stable/main/binary-amd64/Packages.bz2 File has unexpected size (2248 != 2470). Mirror sync in progress? [IP: 23.210.253.5 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Anyone else have the same issue?
