I’m running MATE on a Chromebook via crouton, and it’s running fantastic, I couldn’t be happier.
Am having an issue installing anything from the Software Boutique, and I’m wondering if it’s a crouton issue, or something I can fix.
When I try to install anything from boutique, I get a box saying “You are not allowed to perform this action”. Underneath that it says “You don’t have the required privileges to perform this action”. Under ‘details’ it says: org.freedesktop.PolicyKit.Error.Failed: (‘system-bus-name’, {‘name’: ‘:1.67’}): org.debian.apt.update-cache
Is this fixable? It’s a minor nuisance, I am able to use Ubuntu Software Center by starting it in terminal via gksu. Gksu software-boutique does nothing.
System: Host: localhost Kernel: 3.14.0 x86_64 (64 bit) Desktop: MATE 1.16.1
Distro: Ubuntu 16.04 xenial
