Hello All,
It is good to see a curated list of software to install. It would be even better if you could see the list of packages that will be installed with each entry. With that information someone who wished to do a little research into the software they are about to install would have a starting point. For example, I like to install openssh-server and openssh-sfpt-server so that I can work on my systems remotely. There is a package in the Boutique called OpenSSH but I cannot determine what it installs from the information in the description.
Thanks for any consideration you give this.
