Hello,
Is it possible to connect to a server via FTPS via the Caja File Manager?
Hello,
I don’t think the Connect to Server option in Caja where you choose FTP (with login) actually uses FTP/SSL. So probably not, at least not by just using Caja.
You can however, use the package curlftpfs to mount an ftp host as a local directory
http://curlftpfs.sourceforge.net/
Create the mount point i.e. folder /mnt/host first, of course…
[email protected]:~$ curlftpfs -o ssl,utf8 ftp://yourserver.net /mnt/host
Then it would show up in Caja as a mounted location under “Network”. And you could always set it to mount automatically at startup as the curlftpfs link explains above.
Hello,
Thank you for your response.
I’ve installed the curlftpfs package and I’ve tried everything to get this working. I can see from the verbose that it connects successfully over FTP-SSL but if I try and access the mount point via Caja, it just hangs - nothing happens.
Here’s the syntax I’m using:
sudo curlftpfs -v -o ssl,allow_other,cacert=/home/bstones/cert example.com /home/bstones/website
Am I doing something wrong here?
Edit: Turns out the server was returning its internal IP in its PASV reply. The -o flag has an option called skip_pasv_ip. This ignores the IP address the server returns in its PASV response.
