PI3 - 32GB, Ubuntu Mate 16.04.
How can I connnect a remote X-Terminal (MobaXterm) to my Raspi?
Thanks for your help
One method is to just use ssh. You’ll have to install the server on the Pi.
sudo apt install openssh-server
you could also use x2go to get a full desktop but there are some issues (q.v. see here for solution )
Thanks a lot. It works fine now
