The installation is faulty.
These are the errors I get trying to install the 15.04
1- Fail to start kernel module systemctl system-modules-load services (due to PPI for printer port which does not exist in Pi)
2- gdbm fatal: couldn’t init cache (but continues with install)
3- Failed to start oem-config.service (at this time it just hangs)
If I just reboot after this hang, I get in to the desktop, but eventually, I get
GDBus.Error:org freedestop.DBus.Error
Tried it many times with different Class 10 SD cards. Same result
Installation of Raspbien or Raspex goes without a hitch! So not the hardware.
Any fix?
Hey, just had the same problem ;-]
Found a working solution here:
http://wiki.ubuntu-it.org/Installazione/RaspberryPi
Just Ctrl+Alt+Delete and the boot process resumes !
