Has anyone had any issues with attempts to add PPA repositories?
I just installed 15.04 on my laptop and there are three repositories that I have attempted to add and receive a long string of errors. I installed 15.04 on my desktop not too long ago and added the same PPA repository and didn't run into any issues.
If it helps, here is an example of the string of errors I receive when attempting to add the Synapse PPA:
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 321, in get_ppa_info
ret = get_ppa_info_from_lp(user, ppa)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 91, in get_ppa_info_from_lp
return get_info_from_lp(lp_url)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 87, in get_info_from_lp
return gethttps_content_py3(lp_url)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 101, in gethttps_content_py3
lp_page = urllib.request.urlopen(request, cafile=LAUNCHPAD_PPA_CERT)
File "/usr/lib/python3.4/urllib/request.py", line 151, in urlopen
capath=capath)
File "/usr/lib/python3.4/ssl.py", line 437, in create_default_context
context.load_verify_locations(cafile, capath, cadata)
ssl.SSLError: unknown error (_ssl.c:2738)
During handling of the above exception, another exception occurred:
File "/usr/bin/apt-add-repository", line 119, in
shortcut = shortcut_handler(line)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 837, in shortcut_handler
ret = factory(shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 382, in shortcut_handler
return PPAShortcutHandler(shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 346, in init
info = get_ppa_info(self.shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 333, in get_ppa_info
getsuggested_ppa_message(user, ppa))
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 292, in getsuggested_ppa_message
lp_user = get_info_from_lp(LAUNCHPAD_USER_API % user)
capath=capath)
