[SOLVED] Mate Panel Right click no applet settings
I do not have settings option on right clicking panel applets . Can somebody help ?
I don’t recall exactly where it is but open dconf-editor and I believe under, org>mate>panel>β€œlock panel” … I’m probably wrong of the exact structure and I’m at work on a Windows 7 machine so I can’t check exactly where.
I unlocked it and restarted session every setting ooption is show exept the mate menu one
@IvCHo You’ve been bitten by some massive reworking of MATE Menu. I have fixed it now. MATE Menu should land in the official 15.04 archive very soon. Next update will restore normal behaviour :slight_smile:
You are running an Alpha after all :innocent:
Tnx for the clearance wimpy .
