hi i found a problem with my new installation on my old laptop, i just
discovered the ssd is filling very quickly. after only 2 hours after
installation it was 50% fill without installing nothing more than the
os.
please somebody help me with this problem, i already try with linux
mint and it’s just the same thing the ssd continues filling quickly.
the ssd is a 60gb kingston sata 2 v300 series .
the other problem is the os is consuming almost all the resources of
my laptop (without any app running is using more than 85% of the cpu)
i just appreciate if anybody out there knows how to fix this problems.
greetings
laptop specs: intel core 2 duo 1.50ghz
4gb of ram
kingston v300 series 60gb ssd
greetings…
THANKS AT ALL HELPED ME TO SOLVE THIS PROBLEM
SPECIAL THANKS TO “WOLFMAN”
