[SOLVED] Rhythmbox crashes after pause
Does Rhythmbox crash on anyone else when they select ‘play,’ after coming off ‘pause?’ Any advise?
Does this happen with all types of files or only specific formats? (Eg. OGG’s are fine but crashes on MP3?)
I don’t use Rythmnbox, but I believe it plays files using gstreamer codecs on the system, like banshee and totem.
Hi lah7, thanks for getting back. The only thing I use Rb for is playing Ogg Vorbis audio (audio/x-vorbis+ogg) files. When I select pause, all is fine; but when I press play (for 10 sec or 10 min, etc.) it resumes for a few seconds, and then freezes. If I close Rb (or kill process) everything is peachy, until I pause it again.
Try running Rhythmbox in debug mode - the output it gives may help to solve why it's crashing. :wink:
From a terminal (CTRL+ALT+T):
rhythmbox -d
(Word of warning: It will be very verbose :open_mouth:)
Verbose, huh… are you trying to give me a hint? :grinning:
Okay, its running in debug mode; I’ll paste the results after an hour.
Thanks lah7
Well, lah7, for the first time since installing U-MATE/WW, Rhythmbox is performing perfectly - in debug mode… and now… in normal mode - PERFECT. THANK YOU!! :smile:
I cannot imagine how this magic is possible; here is the last 32,000 characters of terminal data:
file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214164897959, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214188117913, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214234557823, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214257777777, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214304217687, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214327437641, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 213028289726:263000000000(1)]
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214373877551, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214397097505, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214420317460, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214443537414, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214489977324, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214513197278, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 213228477726:263000000000(1)]
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214559637188, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214582857142, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214629297052, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214652517006, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214698956916, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214722176870, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 213429336726:263000000000(1)]
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214768616780, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214791836734, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214815056689, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214838276643, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214884716553, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214907936507, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)214954376417, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)214977596371, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:32) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 213629866726:263000000000(1)]
(17:11:32) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215024036281, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215047256235, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215093696145, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215116916099, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 213830496726:263000000000(1)]
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215163356009, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215186575963, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215233015873, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215256235827, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215279455782, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215302675736, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 214030886726:263000000000(1)]
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215349115646, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215372335600, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215418775510, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215441995464, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)1, prev-timestamp=(guint64)215504399092, prev-duration=(guint64)2902494, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215507301587, cur-duration=(guint64)13061224, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 214231292726:263000000000(1)]
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215566802721, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215590022675, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215636462585, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215659682539, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215682902494, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215706122448, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 214432280726:263000000000(1)]
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215752562358, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215775782312, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215822222222, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215845442176, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [check-imperfect] rb-player-gst-xfade.c:1982: file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg: imperfect-timestamp, delta=(gint64)-1, prev-timestamp=(guint64)215891882086, prev-duration=(guint64)23219955, prev-offset=(guint64)18446744073709551615, prev-offset-end=(guint64)18446744073709551615, cur-timestamp=(guint64)215915102040, cur-duration=(guint64)23219955, cur-offset=(guint64)18446744073709551615, cur-offset-end=(guint64)18446744073709551615;
(17:11:33) [0x257a960] [tick_cb] rb-shell-player.c:2582: tick: [file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg, 214632923726:263000000000(1)]
(17:11:33) [0x257a960] [rb_shell_player_stop] rb-shell-player.c:2119: stopping
(17:11:33) [0x257a960] [unlink_and_dispose_stream] rb-player-gst-xfade.c:1463: stopping stream file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg
(17:11:33) [0x257a960] [stream_pad_removed_cb] rb-player-gst-xfade.c:2121: active output pad for stream file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg removed
(17:11:33) [0x257a960] [unlink_and_dispose_stream] rb-player-gst-xfade.c:1474: unlinking stream file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg
(17:11:33) [0x257a960] [unlink_and_dispose_stream] rb-player-gst-xfade.c:1496: now have 0 linked streams
(17:11:33) [0x257a960] [dump_stream_list] rb-player-gst-xfade.c:502: current stream list:
(17:11:33) [0x257a960] [dump_stream_list] rb-player-gst-xfade.c:525: [pending remove] file:///home/rtlewis1/Music/B/07%20-%20Unknown.ogg
(17:11:33) [0x257a960] [unlink_and_dispose_stream] rb-player-gst-xfade.c:1463: stopping stream file:///home/rtlewis1/Music/B/07%20-%20Unknown.ogg
(17:11:33) [0x257a960] [stream_pad_removed_cb] rb-player-gst-xfade.c:2121: active output pad for stream file:///home/rtlewis1/Music/B/07%20-%20Unknown.ogg removed
(17:11:33) [0x257a960] [dump_stream_list] rb-player-gst-xfade.c:500: stream list is empty
(17:11:33) [0x257a960] [rb_shell_player_set_playing_source_internal] rb-shell-player.c:2055: setting playing source to (nil)
(17:11:33) [0x257a960] [rb_shell_player_set_playing_source_internal] rb-shell-player.c:2078: source is already playing, stopping it
(17:11:33) [0x257a960] [player_has_prev_changed_cb] rb-mpris-plugin.c:1326: emitting CanGoPrevious change
(17:11:33) [0x257a960] [rb_shell_player_sync_with_source] rb-shell-player.c:1882: playing source: (nil), active entry: (nil)
(17:11:33) [0x257a960] [get_times_and_stream] rb-player-gst-xfade.c:2796: not playing
(17:11:33) [0x257a960] [rb_shell_set_window_title] rb-shell.c:2414: clearing title
(17:11:33) [0x257a960] [rb_shell_player_sync_buttons] rb-shell-player.c:1974: syncing with source 0x27fab80
(17:11:33) [0x257a960] [rb_shell_playing_source_changed_cb] rb-shell.c:2257: playing source changed
(17:11:33) [0x257a960] [playing_source_changed_cb] rb-mpris-plugin.c:1302: emitting CanPause change
(17:11:33) [0x257a960] [playing_source_changed_cb] rb-mpris-plugin.c:1305: emitting ActivePlaylist change
(17:11:33) [0x257a960] [rb_header_sync] rb-header.c:970: not playing
(17:11:33) [0x257a960] [playing_entry_changed_cb] rb-mpris-plugin.c:1226: emitting Metadata and CanSeek changed
(17:11:33) [0x257a960] [playing_changed_cb] rb-mpris-plugin.c:1206: emitting PlaybackStatus change
(17:11:33) [0x257a960] [rb_shell_quit] rb-shell.c:2510: Quitting
(17:11:33) [0x257a960] [rb_shell_sync_state] rb-shell.c:1575: saving playlists
(17:11:33) [0x257a960] [rb_shell_sync_state] rb-shell.c:1579: saving db
(17:11:33) [0x257a960] [rhythmdb_save] rhythmdb.c:3222: saving the rhythmdb and blocking
(17:11:33) [0x257a960] [rhythmdb_save_async] rhythmdb.c:3204: saving the rhythmdb in the background
(17:11:33) [0x257a960] [rhythmdb_read_enter] rhythmdb.c:1232: counter: 1
(17:11:33) [0x7ff56400cf70] [rhythmdb_save_thread_main] rhythmdb.c:3152: entering save thread
(17:11:33) [0x7ff56400cf70] [rhythmdb_save_thread_main] rhythmdb.c:3160: no save needed, ignoring
(17:11:33) [0x257a960] [rhythmdb_save] rhythmdb.c:3239: done
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Audio CD Recorder
(17:11:33) [0x257a960] [impl_deactivate] rb-disc-recorder-plugin.c:681: RBDiscRecorderPlugin deactivating
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Internet Radio
(17:11:33) [0x257a960] [rb_shell_display_page_deleted_cb] rb-shell.c:2215: display page deleted
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Close on Hide
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Portable Players
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension MediaServer2 D-Bus interface
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Notification
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension DAAP Music Sharing
(17:11:33) [0x257a960] [impl_deactivate] rb-daap-plugin.c:224: Shutting down DAAP plugin
(17:11:33) [0x257a960] [stop_browsing] rb-daap-plugin.c:412: Destroying DAAP source lookup
(17:11:33) [0x257a960] [libdmapsharing_debug] rb-daap-plugin.c:472: Finalizing DMAPShare
(17:11:33) [0x257a960] [libdmapsharing_debug] rb-daap-plugin.c:472: Stopping music sharing server on port 3689
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Audio CD Player
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Equalizer
(17:11:33) [0x257a960] [pipeline_op] rb-player-gst-helper.c:399: blocking pad /GstPipeline:rbplayer/GstBin:outputbin/GstBin:filterbin.GstGhostPad:sink to perform an operation
(17:11:33) [0x257a960] [rb_shell_player_play] rb-shell-player.c:785: current playing source is NULL
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Media Player Keys
(17:11:33) [0x257a960] [impl_deactivate] rb-mmkeys-plugin.c:473: undoing old-style key grabs
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension Power Manager
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension ReplayGain
(17:11:33) [0x257a960] [extension_removed_cb] rb-shell.c:816: deactivating extension MPRIS D-Bus interface
(17:11:33) [0x3d8e320] [really_remove_filter] rb-player-gst-helper.c:559: removing filter 0x30ec100
(17:11:33) [0x3d8e320] [really_remove_filter] rb-player-gst-helper.c:586: filter removed
(17:11:33) [0x3d8e320] [really_remove_filter] rb-player-gst-helper.c:559: removing filter 0x32222d0
(17:11:33) [0x257a960] [sync_window_settings] rb-shell.c:1925: paned position 160
(17:11:33) [0x257a960] [sync_window_settings] rb-shell.c:1932: right_paned position 877
(17:11:33) [0x257a960] [sync_window_settings] rb-shell.c:1939: sidebar paned position 175
(17:11:34) [0x257a960] [rb_static_playlist_source_dispose] rb-static-playlist-source.c:198: Disposing static playlist source 0x27f8360
(17:11:34) [0x257a960] [rb_playlist_source_dispose] rb-playlist-source.c:407: Disposing playlist source 0x27f8360
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page Play Queue (13)
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page Music
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page Podcasts
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page Missing Files
(17:11:34) [0x257a960] [rhythmdb_query_model_dispose] rhythmdb-query-model.c:731: disposing query model 0x29bf170
(17:11:34) [0x257a960] [rhythmdb_query_model_finalize] rhythmdb-query-model.c:779: finalizing query model 0x29bf170
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page Import Errors
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page New Episodes
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page New Downloads
(17:11:34) [0x257a960] [rb_playlist_source_dispose] rb-playlist-source.c:407: Disposing playlist source 0x26ccf40
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page My Top Rated
(17:11:34) [0x257a960] [rb_playlist_source_dispose] rb-playlist-source.c:407: Disposing playlist source 0x26cd1d0
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page Recently Added
(17:11:34) [0x257a960] [rb_playlist_source_dispose] rb-playlist-source.c:407: Disposing playlist source 0x26cd460
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page Recently Played
(17:11:34) [0x257a960] [rb_static_playlist_source_dispose] rb-static-playlist-source.c:198: Disposing static playlist source 0x3680e60
(17:11:34) [0x257a960] [rb_playlist_source_dispose] rb-playlist-source.c:407: Disposing playlist source 0x3680e60
(17:11:34) [0x257a960] [impl_dispose] rb-display-page.c:546: Disposing page 17 California Dreamin’.wma
(17:11:34) [0x257a960] [get_times_and_stream] rb-player-gst-xfade.c:2796: not playing
(17:11:34) [0x257a960] [rb_xfade_stream_dispose] rb-player-gst-xfade.c:426: disposing stream file:///home/rtlewis1/Music/Pachelbel:%20Canon%20-%20Baroque%20Favorites/02%20-%20Concerto%20grosso,%20op.%206%20no.%206:%20Larghetto%20e%20staccato%20-%20Allegro.ogg
(17:11:34) [0x257a960] [rb_xfade_stream_dispose] rb-player-gst-xfade.c:426: disposing stream file:///home/rtlewis1/Music/B/07%20-%20Unknown.ogg
(rhythmbox:4323): Gtk-WARNING **: mnemonic “s” wasn’t removed for widget (0x276c690)
(17:11:34) [0x257a960] [rhythmdb_process_one_event] rhythmdb.c:2572: processing RHYTHMDB_EVENT_DB_SAVED
(17:11:34) [0x257a960] [rhythmdb_read_leave] rhythmdb.c:1246: counter: 0
(17:11:34) [0x257a960] [rhythmdb_process_one_event] rhythmdb.c:2569: processing RHYTHMDB_EVENT_THREAD_EXITED
rtlewis1@rtlewis1-OptiPlex-780:~$
No problem @mated :slight_smile: :thumbsup: Must have been a fluke this round... or debug mode did something to nudge Rhyhmbox to behave for the people :wink: :camera:
@lah7: Yeah, pause/play is still behaving - even after several launch/kills; :dizzy: I’ll know for sure, I guess, after a reboot. Truth be told, I waited several weeks just to be sure, before posting about the bug. Other than for the GNOME Main Menu 1.8.0 crashing, infrequently, Rhythmbox was the only flaw in my total U-MATE/WW experience. Wonderful stuff you guys - thanks again! :sparkles: :star2: :sparkles:
