Using the steam-controller doesn't work in Ubuntu MATE 17.04 for me.
Terminal-Output starting sc-controller:
> morten@caladan:~$ sc-controller
> Traceback (most recent call last):
> File "/usr/bin/sc-controller", line 27, in <module>
> from scc.gui.app import App
> File "/usr/lib/python2.7/dist-packages/scc/gui/app.py", line 11, in <module>
> from scc.gui.controller_widget import TRIGGERS, PADS, STICKS, GYROS, BUTTONS
> File "/usr/lib/python2.7/dist-packages/scc/gui/controller_widget.py", line 15, in <module>
> from scc.actions import Action, XYAction, MultiAction
> File "/usr/lib/python2.7/dist-packages/scc/actions.py", line 14, in <module>
> from scc.uinput import Keys, Axes, Rels
> File "/usr/lib/python2.7/dist-packages/scc/uinput.py", line 38, in <module>
> CHEAD = defines('/usr/include', 'linux/input.h')
> File "/usr/lib/python2.7/dist-packages/scc/cheader.py", line 85, in defines
> lexer = shlex.shlex(open(fname), posix=True)
> IOError: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/usr/include/linux/input.h'
[Datei oder Verzeichnis nicht gefunden -> translates to "file or directory not found")
Apparently Ubuntu MATE has no files in the directory /usr/include/linux/
Having a Xubuntu 17.04 installation nearby i can confirm that there are many files in that dir.
Touching input.h:
morten@caladan:~$ sc-controller Traceback (most recent call last): File "/usr/bin/sc-controller", line 27, in <module> from scc.gui.app import App File "/usr/lib/python2.7/dist-packages/scc/gui/app.py", line 11, in <module> from scc.gui.controller_widget import TRIGGERS, PADS, STICKS, GYROS, BUTTONS File "/usr/lib/python2.7/dist-packages/scc/gui/controller_widget.py", line 15, in <module> from scc.actions import Action, XYAction, MultiAction File "/usr/lib/python2.7/dist-packages/scc/actions.py", line 14, in <module> from scc.uinput import Keys, Axes, Rels File "/usr/lib/python2.7/dist-packages/scc/uinput.py", line 56, in <module> Keys.KEY_ESC: 0x70029, File "/usr/lib/python2.7/dist-packages/scc/lib/enum.py", line 422, in __getattr__ raise AttributeError(name) AttributeError: KEY_ESC
It has to be a MATE thing as sc-controller works under Gnome, Xfce 17.04 and Linux Mint 18.2.
Is there a workaround? Or are simply some packages not installed?
Help is much appreciated,
Scytale
