NoXoN
1
Hello,
my Wifi suddenly stopped working and showing that “Device is not ready”
I checked “rfkill” nothing is blocked
I checked any upgrade and update using apt-get , everything is fine.
I tried my ALFA adapter to connected to the internet and everything is fine
note : my internal wifi adapter is ralink
any suggest where should I start ?
Thanks in advanced!
Hi @NoXoN,
please paste the following command in a terminal (Ctrl + Alt + t) and post the results back here so we can see what hardware you:
lspci
or
lshw
NoXoN
3
Ok,
Today I came back from work turned on my laptop to check this topic.
I found out that wifi still not working and I have to check using my tablet,
I said let’s do something with terminal, all I did was “sudo modprobe rt2800pci” … and tadaaa … connected.
to be honest I have no idea what caused this problem , my wifi card not even blacklisted or blocked “rfkill list”
so we can say the problem sovled … Thanks!
