Sonos controller not working
Dear All
I am running 16.04 mate and own a sonos system. How can I install a controller?
The chromium app gets stuck with the message: Searching for your sonos system.
The apk install via welder does not work either.
Suggestions?
Thanks
You could try running the Windows version via wine (check out this how-to, although it’s for Ubuntu 14.04).
Thanks. I am anyway planning to set up W7 in a VM. This would do the trick then, I guess.
