I had an unexpected power outage the other day. I was working on my Raspberry Pi (with MATE) at the time, and as a result of the power loss it obviously shut down. When I got power back five minutes later, the machine wouldn’t boot. It comes up to the Ctrl-D prompt, and a second or two later the MATE logo with the chasing dots underneath replaces that. The machine just “sits” there.
I know what the problem is because I’ve been there with other Linux systems. The Ctrl-D prompt serves a purpose everywhere but on the MATE/Pi setup; it does nothing but switch to that logo screen described above. I know how to work around it because I’ve swapped the MATE card for my Raspbian one so I can run fsck
on it. After this, the card is back to normal.
What I don’t know, and which I hope someone here can tell me, is whether there’s a way for me to add a recovery method that will allow me to forego the roundabout repair? Even though I have the means to do the described roundabout fix, I’d much rather keep it self-contained.
Thank you
